11-10-2017 10:43 PM - edited 01-04-2022 02:55 PM
11-10-2017 10:51 PM
Just sent! I'm assuming this mistake happens. Thanks for the quick reply.
11-10-2017 10:50 PM - edited 11-10-2017 10:51 PM
@Ppowless wrote:Will do, If i select options to make a change it wants to charge me another $144. 😕
Yes, since its a prepaid service, that "Change Now" option will charge you the full amount for the new plan and will not receive any credits for already paid plan. You will have to send a message to the mods.
11-10-2017 10:48 PM
11-10-2017 10:46 PM - edited 11-10-2017 10:47 PM
@Ppowless Send a private message to the Moderator_Team with your account details and an explanation. They will get back to you tomorrow. In the mean time, don't make any changes to your account.
