04-24-2019 06:09 PM - edited 01-05-2022 04:34 AM
For the 100 minutes plan. How do you get a summary of how much call minutes I’ve used so far. I only see it for data usage
04-24-2019 06:28 PM
@Mustangmike wrote:
- Usage history doesn’t show any totals. I’m not going to add them up. Maybe it’s out of minutes so I don’t see the summary on the first page
Yes if you can't see no minutes on your first page it's because you used all.
04-24-2019 06:27 PM
That's correct. If you don't see the three lines of the three components of the plan in your data and add-ons area then one or more are consumed. Then they disappear until the plan renews.
04-24-2019 06:22 PM
04-24-2019 06:14 PM
@Mustangmike wrote:For the 100 minutes plan. How do you get a summary of how much call minutes I’ve used so far. I only see it for data usage
@MustangmikeFrom the selfserve main page click on View My Usage
04-24-2019 06:13 PM
If you have minutes left you can see them on the first page of your self-serve account....as 25/100 minutes...for example. Or you can see the details in tab PLAN/OPTIONS and USAGE HISTORY.
04-24-2019 06:12 PM - edited 04-24-2019 06:13 PM
Log in to the "My Account" and click "View My Usage" (it's right under the change plan button) in the "My Plan" box that details the name of your current plan.
