Chatbot link is not loading
hi All, the direct chatbot link https://publicmobile.ca/chatbot  is not loading. Anyone have the same issue?
However, if i login to My Account, click Chatbot on top, then it loads
7 REPLIES 7
@hTideGnow wrote:
thanks @LitlLdy  and @Meow
now, i need to find the quickest way to  get to open ticket
@hTideGnow , me to! Been messing with it. If I succeed I will report back!
LitlLdy
@hTideGnow , my link is different & look weird but work!
Edit: I’m soo slow at typing! 🤣
Meow
You can get to chatbot using this link or through Main Page - Help
thanks @esjliv   for the link.
Look like we cannot just submit a ticket using "Other"as the option like before.  seems like you have to really go through the Chatbot exericse.
@hTideGnow - my links I use (copy/paste) work okay.
I also notice this works from the My Account site:  ITIA Chatbot (tiia.ai)
@hTideGnow
I am trying to get use to the new Community website page…not use this cartoonish format yet.
It could be the cut and paste issue. Not sure though.
