ChatGPT Advanced Voice Mode Issue
pj39jameson
Hi there,
Is anyone else having issues using ChatGPT's advanced voice mode while on cellular network? I get the error that it can't connect every time. Works fine when I'm on wifi or if I install a VPN to use while on cellular. This service worked fine for me while I was on my iPhone 13 pro. Now I have a iPhone 17 pro and the latest OS and haven't been able to get it to work at all.
I have dealt with ChatGPT, public, and apple support to try and resolve this and jumped through all the hoops. Reinstalled the app, reset network settings, event reset my sim, tried a different openAI account, tried different models, etc. My best guess is that it's an issue with the latest OS and the permission handshaking between this version of OS and the ChatGPT app. I have asked openAI to elevate this to their developers.
If you have this issue please chime in.
11 REPLIES 11
hi @hkbsws
have you ask PM support agent to check? refer them back to the solution on this thread and ask them to escalate
submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
hkbsws
I have the same issue by 17 pro max
Carina33
@pj39jameson hooray!!  Glad it’s fixed!
@pj39jameson
You are welcome.
glad that  message linked  you to the right person with the same issue and now issue is fixed
pj39jameson
Thanks for the solution! This fixed the issue for me.
Carina33
Please see my reply in this thread. I also spent countless hours with my IT team and the Apple Store to try and rectify the problem.  It is Public Mobile carrier service that is blocking the app.
Carina33
Yes it is a problem with the carrier. I spoke with Telus IT and he told me it affected ChatGPT voice function as well.  They only called me after I requested it for my issue to be escalated.
When my plan was changed recently, I was moved from IPV4 to IPV6 - the IPV6 (Internet protocol 6) is the problem.  This only took effect over the last 2 weeks.  IT switched me back to IPV4 and it solved my problem with my Webex app.
Please have your issue escalated to the IT at Telus/Koodo and tell them it’s a routing problem and you need to be switched back to IPV4.
@pj39jameson and @holymackinaw88
did you lately upgrade your plan?  it was confirmed from another community member that it could be a problem with the protocol
https://productioncommunity.publicmobile.ca/t5/Get-Support/Useless-customer-service/m-p/1393114/high...
Open another ticket with PM and ask them to escalate to Telus Support, ask them to refer back to that post
(or  @Carina33 , can you share your Helpdesk ticket # so they can refer to it? thx)
pj39jameson
I don't think it's the carrier seeing as it was working fine all year for me on my iphone 13. Are you running the latest version of iOS?
holymackinaw88
New in Town / Nouveau en Ville
I'm having the same issue. I think it's carrier related but unsure how to have this fixed
HI @pj39jameson
my chatgpt works well on mobile data
