05-10-2015 11:26 AM - edited 01-04-2022 12:38 PM
Can you confirm that all incoming calls are free of charge, whether they come from Canada or international, on all Public Mobile plans? And that there is no limit to the amount or duration of incoming calls?
07-26-2018 04:46 PM
@Jencho wrote:Make sure you have Canada wife calls,
if home province is in Ontario
you will be able to phone and receive calls from any province
example I was in Vancouver I made calls to Alberta and Ontario
@Jencho thanks for trying to help--but you're replying to a thread that hasn't been touched in over 3 years. Nobody is waiting for a reply on the subject.
07-26-2018 04:31 PM
05-11-2015 02:18 AM
05-10-2015 10:33 PM
05-10-2015 10:29 PM
Oh, Thanks for pointing that out @Martin
05-10-2015 10:26 PM
05-10-2015 01:13 PM
Yes. @Cyber, thanks for pointing that out. @Cordulia, Prov-wide Talk is only exception. U can only call within Prov of which your area code, so if 416, 437, 905, 519, 647, that's On, and if U leave Prov to go to Que, example, U will need to Purchase a Long-Distance Add-on to make calls or receive calls
05-10-2015 11:56 AM
Not true for Province-Wide 2
05-10-2015 11:34 AM
Fabulous! Thank you!
05-10-2015 11:32 AM
Hello. Yes, All Incoming Calls, Domestic and International, are Free.
