Charged twice
pkane
Hi i was charged twice.
on the 23rd I autopaid 42.50
then on the 24th I wanted to buy more data so I put on another 42.50 using top up, calling 611.
When I checked my account balance after to add a GB it said I had ten dollars.
I called the bank and they confirmed to payments of 42.50.
Then another for 20 dollars which I paid again after to be able to get my account to 30 dollars for a GB.
I want my 42.50 back and I can provide a bank statement if necessary to get it.
Please, fix this for me!
dabr
I'm not sure I understand why you needed to add another $42.50 to purchase the add-on which is $30+tax?
However, you shouldn't have been charged twice, so as suggested you should contact the moderators, I'm sure they will reimburse you any overpayments, but it'll probably be as a credit in your account which will mean your next month's bill be paid from those funds first.
Maple98
@pkane  - I may be reading it wrong, so just to clarify... did you authorize all charges from your bank account but just made more payments than you meant to ($42.50 on the 23rd & one more payment of $42.50 on the 24th)? Or were you charged $42.50 on the 23rd plus a total of $85 (42.50 x 2) on the 24th?
If it was the 1st scenario, you may still be able to contact your bank, explain that it was made in error & ask if they can reverse 1 payment.
If it was the latter situation then, as @hairbag1 mentioned, you will likely need to contact the moderator team
to have it corrected.
geopublic
@pkane Best to check your payment history online to get a better understanding on what happened. If you post a screenshot minus personal info we can help you dicepher what happened.
hairbag1
Sounds like you'll need to contact the moderators for their assistance....Click this to message them
Please be patient as it could be up to 48 hours before you get a reply....usually less though.
