07-04-2024 12:33 PM
My subscription expired so I went to manually pay it this month. I was charged twice and do not see a credit on my account.
03-31-2025 04:32 AM
I upgraded my plan just after my renewal date, and I was charged twice, once for my old plan and once for my new plan, in the same billing cycle.
I put in a ticket for a correction, but I may just contact my credit card company and do a duplicate charge as I didn't benefit from the first charge; I didn't use that plan.
07-04-2024 01:05 PM
Great, thanks so much for your help!
07-04-2024 12:43 PM
I would definitely reach out to a CS agent in that case. Click on the round orange circle in the bottom right corner or click on either of the links I provided above. Shouldn't take long for them to fix the double charge
07-04-2024 12:39 PM
On both actually, my account and my banking app. This was almost a week ago so I waited a few days to see if it would correct itself but it has not. Still seeing 2 charges for $35.70 on my bank
07-04-2024 12:36 PM - edited 07-04-2024 12:38 PM
@CrystalBoisvert are you seeing the double charge on your PM account or on your banking? If you are seeing it on your credit card account online it's possible that you are seeing a pending charge and the actual. I have seen this on my own account and usually within 24 to 48 hours it's cleared up. If you are definitely seeing double charge a CS agent should be able to clear it up but you will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
