Changing to auto pay
Autismmom23
How do I change my settings to auto pay
bhavpate4
I don't believe it will work. it will still need to have CC on file . as long as CC is on file that should work out.
dude65
One thing I tell people who have PM and use auto pay is that autopay has screwed up before and you can manually add funds from the CC on file at anytime and still get the autopay reward.
Triguy
To set up AutoPay, sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘Register for AutoPay’. From here, you can sign up for AutoPay or remove the feature, if you no longer want payments to automatically occur. If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
JoyLuck
You need to log into self service. Choose Payment tab and put credit card on file. There is then an option for autopay.
If you already have a credit card on file call 611 from your phone to turn on autopay.
