Changing the plan
Dr_K
Why can't I see the plans cheaper than the plan I have. I want to downgrade.
2 REPLIES 2
SKSuh
Downgrading is indeed possible — I have done it twice — but it requires patience by checking which options are available at least once per week
hi @Dr_K
downgrade is possible, but you won't have many choices
check often and it will come
