Changing subscriptions from LTE to 5G
space-jim31
Hi there. I'm currently on a LTE/4G subscription (40 CAD a month, for 15GB at 4G speeds) and just saw that PM are running a promo for 5G speeds, 50GB for 35 CAD a month.
My question is, if I changed my subscription, will my iPhone 11 (which is not 5G compatible) still be able to use the network? I notice it says *up to* 250mbps. So does that plan still have the ability to connect to LTE? Or is it *only* 5G?
Forgive me if this is a dumb question - but if it is possible, it wouldn't make sense for me to stay on the 40 a month plan for literally less than half the data allowance.
Thank you
space-jim31
Ok thank you guys!
This was my first time using this customer help community tool and I gotta say - super helpful. Thanks again
@space-jim31  Yes the price will be locked in at $34 every 30 days . And even thou you phone is not 5G compatible you will still see better speeds of the 4G plan 100Mbs. With phones set to 4G/LTE on a 5G plans
hairbag1
@space-jim31
that new plan will work great on your iPhone 11. ..leave it on LTE. You'll noticed marked improvement in download speeds. That new $34 plan is superior to your existing $40 plan.
follow-up answer...
if you take that new $34 plan...it's $34 + tax going forward...BUT...Pm does reserve the right to change the terms if it chooses.
space-jim31
Also - follow up question. If I buy this promo subscription at that price. Will it be 35CAD permanently moving forward? Or will it go up?
