Changing public mobile phone number
samcat
I've seen other community postings about this but just going to ask so I can confirm the latest answer. I currently have public mobile phone number.
- Where can I find the full changing phone number policy?
- I've read that you can change it 4 times in 1 month, but I think I've also read in the past that you can only change it once every certain number of days. Is it possible to change my phone number for a few weeks but then change it back to my old number after if I change my mind? What is the likelihood of my phone number still being available?
- Is there anything to be aware of/ any problems or errors that might come up to change a number or change back?
- Does public mobile allow you to input 7 digit phone number to check availability, or does it list options only?
Thank you
2 REPLIES 2
@samcat
No you can't bring back old number when you did changing,
Changing Your Number,
You can change your phone number up to 4 times every 30 days after you’ve activated. To change, go to your Self Serve Account here link, and:
  • Select the “Plans and Add ons” tab
  • Click on “Change Phone Number”
  • Then, you can choose to select a new phone number or to transfer a wireless or wireline number from another provider.
You cannot enter 7 digit number and check availability that way.  They give you 5 or 6 choices and you pick from there.   If you don't like them, change city and change back to the city you want and they will give you another set of numbers
4 times every 30 days.  You CANNOT change back to original number if you don't like the new one
this is the official reference
Port Fraud Protection (publicmobile.ca)
