06-21-2023 06:20 PM
Can I change from 25 dollar monthly plan to pay as you go? Like a $0 plan/ monthly if I dont make calls/ use any data and still keep incoming calls active.
Please let me know how.
06-21-2023 06:48 PM
no pay-as-you-go option here. Take the $15 plan to start and see if you can manage with that If you need more calling minutes you can get a $5 / 500 minutes of Canada wide calling add-on OR upgrade to a plan with Unlimited Canada wide calling minutes...$25 is suggested.
If you happen to be in La Belle Province there's several other options for you to investigate.
06-21-2023 06:42 PM
@Anukul The $15 plan should be better for you then it’s unlimited incoming calls unlimited texts . Only 100 outgoing minutes
06-21-2023 06:26 PM - edited 06-21-2023 06:28 PM
@Anukul , the lowest plan Public Mobile has is the $15 Plan with data at 3G speed, there’s none that are for $0
