Changing phones with eSIM
Dave5150
Hi everyone- I know swapping a sim between phones works but now I have an eSIM and want to replace my broken phone, can I do this online or do I need customer support? Thx
2 REPLIES 2
Dave5150
Thank you
@Dave5150
if you can login, you can do it yourself (you can use email to receive 2FA, or use voice message if you know the voicemail PIN.  At the 2FA screen, click Didn't Receive Code or Resend Code, and choose either email or voice message)
eSIM cannot be moved.  BUT Luckily, you can get a replacement for FREE
To rebuy new eSIM for FREE, first, download the app on your new phone and login.  If you have problem with receiving 2FA code, click "Didn't Receive code" or "Resend code" and choose either Send email or Send voice message
Once logged in, Click Account from the bottom, then click Purchase SIM Card and select eSIM
Once it confirms your phone is eSIM compatible, click Pay $  and Install (the system will check and apply a $5 credit to bring the total price back to $0 at checkout), and follow the prompt to complete and purchase and install eSIM on your device
(in rare case that PM charges you for the replacement esim, you can submit a ticket with PM support and ask them for reimbursement)
https://www.publicmobile.ca/en/on/get-help/articles/get-a-sim-card
Existing eSIM users at Public Mobile who need a replacement can do so at no extra cost. When you request a new eSIM through the usual process, we automatically identify you as an existing eSIM user and waive the replacement fee. See below for steps on how to get your new eSIM.
