Changing my subscription
Natalia33
I need to change my subscription to $20 dollars one but it doesn't give me the option. I tried in browser and app as well.
1 REPLY 1
Sansan
Sorry,  if you have a more expensive plan, than what you desire, you most likely won't see the twenty dollar plan.
So if you don't see it, that means you can't change, to it. You can only change the next ones below been offered.
The website,  is for the general public and not necessarily for existing members.
