Changing email address
Smangie22
Need to change email address for my spouse's account and can't access online account as the email account has been deactivated. Please advise!
Moved:
will13am
@Smangie22 , you should still be able to access the self serve account even if the email address used to set up the account is no longer working.  The 2FA code can be sent via text.
dust2dust
Just to explain, if you were to gain access then you wouldn't be able to change it yourself anyway.
The email is just a login id. If the account is not suspended then you can send a text to the phone for verification rather than email.
JK8
@Smangie22
Contact an agent to have them change the email.
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
  • Monday to Sunday: 6 AM to 10 PM EST
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
