03-25-2021 03:59 PM - edited 01-06-2022 01:33 AM
When I go into self serve I am unable to get the system to recognize my email address. I don't remember my password and simply want to change the credit card making payments on my account.
03-25-2021 06:25 PM
You need to contact a PM moderator by clicking on SIMon chat bubble and ask to contact the moderator.
03-25-2021 04:19 PM - edited 03-25-2021 04:20 PM
If you're sure you're using the correct email, try clearing cache and cookies, opening an incognito tab and MANUALLY enter email (if you may have been using an auto complete before...)
Then, use the forgot password function. After successfully resetting password, here's some tips to successfully amending credit card to avoid the things that can glitch:
03-25-2021 04:17 PM
Did you try Forgot Password and try with any email you might have used. It might work 🙂
03-25-2021 04:12 PM
What happens when you dial 611?
Look in all your inboxes for the welcome email from here. That email address will be your login id. Then you can use the Forgot your password? link to reset your password. The reset email will go to that address.
03-25-2021 04:07 PM
@BryonRobertson wrote:When I go into self serve I am unable to get the system to recognize my email address. I don't remember my password and simply want to change the credit card making payments on my account.
Please contact support by opening a ticket through: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
