07-02-2020 04:56 PM - edited 01-05-2022 11:56 AM
07-02-2020 05:41 PM
@LEDoyle ,
Yes, you can go to a PM kiosk or click the bottom right hand question mark and submit a ticket and a moderator will port it for you.
You will need your old phone number and account number if it is with a different provider.
It might take a few hours to a day to port it over.
Eliza5
07-02-2020 05:36 PM
Yes, you can, but only if that old phone number is still active. Doing so will close your old phone number account. In self-serve, go to the "change phone number" tab to port your number over.
07-02-2020 05:24 PM - edited 07-02-2020 05:25 PM
@LEDoyle wrote:Can I change my phone number to a number on my previous phone?
Here’s the information you’ll need:
To complete your port-in request, click this link and type in “port request” to be put in touch with a Moderator.
07-02-2020 05:02 PM - edited 07-02-2020 05:03 PM
If you are asking if you can transfer/ port your number from a different provider, then the answer is yes @LEDoyle . Currently to port your number once you have activated with a temporary cell phone number. You require moderator( PM customer service) help. Type " Port Request " and follow the prompts to get to one. Give them the name on the account, the number to port and the old provider's account number. . Please note, your oldproviders account must be active to port. The port will close it once its completed. There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
Welcome to PM .
