07-18-2018 02:49 AM - edited 01-04-2022 06:28 PM
07-18-2018 04:05 PM
I can change my self serve email back to the regular one, correct? Because my username is only that number on the community, I didn't think it would be my screen name.
07-18-2018 02:06 PM
@SolomonT Seems you are new, so just change its associated email address then create a new username with the email address of your self serve account. 778 will just disappear from the radar. 60 seconds and all done!
07-18-2018 08:32 AM
@MoreYummy wrote:You dont like your special name anymore? Is it lottery number?
If I were to guess, this is a phone number. Not the wisest choice for a community username.
07-18-2018 03:35 AM
You dont like your special name anymore? Is it lottery number? ![]()
07-18-2018 02:50 AM
@SolomonT Once again you will need to send a private message to the Moderator_Team with that request as well.
If it helps, you can always search the community as the same questions might have been answered before.
