09-07-2023
07:31 PM
09-07-2023
07:39 PM
computergeek541
Hi,
How do I change from a 30 days subscription to a 90 subscription? There is no option to do this on the self serve portal. I am currently on the $39 4G plan.
09-07-2023 08:15 PM
The 90 day version of the $39/20GB plan ($102/60GB) was a promo that expired on September 5th. Check back often, as plans and promos come and go very quickly these days.
09-07-2023 07:41 PM
@Genji_Genji - are you on mobile or desktop as things look a bit different.
Here is how you can change plans/subscriptions : https://www.publicmobile.ca/en/ns/get-help/articles/change-your-plan
09-07-2023 07:40 PM
Ah OK, guess I'll have to wait till that promo comes back around. Thank you @computergeek541 , @dust2dust, and @Handy1 for the help.
09-07-2023 07:38 PM
09-07-2023 07:37 PM
Plans have been coming and going a lot for the last while. That was a promo.
09-07-2023 07:35 PM
That is odd because my daughter has the exact same plan and she was able to switch her 30 days subscription to a 90 days one.
09-07-2023 07:34 PM
@Genji_Genji .only certain plans have the option for 90 days and the ones that do you have to pick it first then get the option for 90 days . For example there’s a 50GB for $55 select it and you can go 90 days option where you pay $150 upfront with 150GB for 90 days
09-07-2023 07:32 PM
There are only two plans eligible for the 90 day option. Not all.
