Changing 2FA from SMS to Email
Slawek24
Is there a way to change the 2FA code to be sent to email instead of an SMS?  Unable to receive codes while overseas where SMS will not work.
Thanks
2 REPLIES 2
kb_mv
@Slawek24 Select "didn't get code" and you should be given the option to select "by email"
hi @Slawek24
all you need to do is to click "Didn't receive code" on the security code step, and then select Send email
