10-08-2021 07:40 PM - edited 01-06-2022 03:44 AM
I previously had 0.5gb of data on my plan, but was rewarded an extra 0.5gb of data for being registered with auto-pay (1gb total). I recently upgraded my plan to include 3gb of data/month and when I selected this option it said "3gb + 0.5gb with Auto-Pay" and I'm not seeing this extra 0.5gb on my plan at the moment. Why is this? It seemed to have been advertised that way when I selected this option.
*Edit: I was mistaken.. I selected 2.5gb + 0.5gb. Thanks for all the replies!
10-09-2021 12:59 AM
@pkaraa wrote:I think you are mistaken for this as 3 GB data plan is not there, it was 2.5 + 0.5 with autopay.
Please note that this was already stated several hours ago. Your eagerness to participate is appreciated. However, please check for repetition before making future message posts.
10-09-2021 12:49 AM
10-08-2021 08:06 PM
that i learn from my dear best friend a VIP person @darlicious
you mean to i can change what i like to do and no one can see it .....funny..
thank you...
10-08-2021 08:01 PM
@Anonymous another thumb up.. I think this is a good format you can consider keep using.. answer the question directly first.. then add the notes how to contact CS Agent as a spoiler. It is neater as it looks like a shorter post.. and you also have a chance to post everything that you want to say.
10-08-2021 07:56 PM
10-08-2021 07:55 PM - edited 10-08-2021 07:55 PM
@Anonymous yes, you were asking OP to contact CSA. I guess you were updating the post while I was posting.. no problem.. but yournote helps to avoid misunderstanding.👍
10-08-2021 07:53 PM - edited 10-08-2021 07:55 PM
@Anonymous - there is no issue for CSA here, Unless the OP received some kind of targeted offer.
Details make all the difference.
You edited, okay makes sense now.
10-08-2021 07:52 PM
@llevesque wrote:I previously had 0.5gb of data on my plan, but was rewarded an extra 0.5gb of data for being registered with auto-pay (1gb total). I recently upgraded my plan to include 3gb of data/month and when I selected this option it said "3gb + 0.5gb with Auto-Pay" and I'm not seeing this extra 0.5gb on my plan at the moment. Why is this? It seemed to have been advertised that way when I selected this option.
All the best,
Leo
Sorry, but there is NO current in market plan with 3GB + 500mb(with Autopay).
Have a look at the options under the Change Plan area on your Self Serve, and you will not see that option.
Also, See here:https://www.publicmobile.ca/en/on/plans#plans-start
10-08-2021 07:47 PM - edited 10-08-2021 07:48 PM
@llevesque Let's not contact PM agent yet
did you just changed to the $35 plan? if so, this is what included with $35
So, the data is 2.5GB +0.5GB with Autopay
10-08-2021 07:42 PM - edited 10-08-2021 07:57 PM
update @llevesque
for $35
or Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,
Good Luck..
as i did check it you did post it,,
