Changed Plans
Baylee13
Hi,
Last night I changed my plan to a $40 plan.  My Credit Card was charged but under account it is still showing my old $60 plan.   How long does this take to change?  Thank you
Baylee13
Thank you, I just did that and it is showing up now.  Thanks for your help
HI @Baylee13
the change is immediate if you click "Change Plan now"
but PM site has poor cache management.
Clear cache and relaunch browser
or use Private or Incognito mode to check My account
Outdoorsman
@Baylee13 hi there is a cache issue with accounts,use a different browser in private or incognito mode sign back in and see if it clears up
walker1
@Baylee13
Try logging into your account using a browser in incognito or private mode first.
Your probably looking at old cached information.
Also, the 4 G speed won't show up for about 48 hours from your switch to the 4G plan though.
