Changed Credit Card
Willow536
Hello PMer's
I had my credit card renewed this past month and my autopay date is coming up. I received a text from PM that my card was about to expired...which I knew and the reasong for getting my card renewed. Will PM still accept my credit card on file because my name and  the 12 digit number on the front is the same but the expiry date the security code on the back? or Will I have to remove it and then reapply it?
Thanks PMer's
2 REPLIES 2
I think safest procedure is to remove your card then add it again. stonechucker's suggestion is the MINIMUM you should do.
stonechucker
you will need to update the expiry date, and possibly the number on the back of the card.
if you do not update this info, it will fail.
