My internet doesn’t work anymore!!
Charly16
My internet doesn’t work anymore, I checked my account and I should still have 4GB left. I can still make calls and my phone (iPhone) shows me that i have service and LTE but nothing works
@Charly16 Glad you got it sorted. Are we to assume you had a profile from a previous provider? Did network reset fix the issue?
CalgaryBen
@Charly16 have a look at this thread, and also see if this post is applicable to you.
Is your local data manager set for a monthly plan, and the dates are off due to Public Mobile being 30- or 90-day cycles?  Could your personal setting for data use be used up, and needs to be deactivated?
krazykiwi
Have you tried switching Airplane mode on then off?
Reset network settings?
Is this a new account?
