12-15-2024
07:41 PM
12-15-2024
10:01 PM
computergeek541
I need support to help me upgrade my existing 4G plan to a new 5G 50 GB Canada-US-Mexico subscription ($35.00). The website won't allow me to do this.
12-15-2024 08:17 PM
12-15-2024 08:15 PM
Thanks. The mobile app worked perfect!
12-15-2024 08:12 PM
of course, customers have the right.
I just think as a regulars, we should give responsible advises and just not send customers to CS agent when we know the answer. And also, I am giving you the official stance for PM on this issue
12-15-2024 07:48 PM - edited 12-15-2024 07:49 PM
@softech wrote:
@Chalupa_Batman wrote:
@AndySnelleman wrote:I need support to help me upgrade my existing 4G plan to a new 5G 50 GB Canada-US-Mexico subscription ($35.00). The website won't allow me to do this.
Hello @AndySnelleman
Try using the app, it tends to work better. If that's not helpful, please connect with a CS Agent via this link.
support won't be able to help to change to plans that are not found on user's Change Subscription page. Please avoid directing customers to contact an agent for that. thanks
Hello @softech Customers have the right to contact CS Agents to ask for assistance with changing their plans. It's then up to the CS Agent to decide. Since you nor I work for Public Mobile, it's not up to you or I to tell them otherwise.
12-15-2024 07:46 PM
12-15-2024 07:43 PM
sorry @AndySnelleman , you can only upgrade to plans available on your My Account. Support wont' be able to change to plan that is not available on the Change Subscription page on your account.
For Canada/US/Mexico plan, you should see the $45 and the $55 plans and you can change to one of the two instead
12-15-2024 07:42 PM
