11-06-2019 01:07 PM - edited 01-05-2022 07:53 AM
11-06-2019 11:45 PM
I know that when you choose the plan you want you have to click [change plan now ]if its before your montly renewal date that you are trying to change your plan .if not the new plan will only be change on your montly renewal date.i hope this helps.
11-06-2019 08:49 PM
Actually i tried to once and i did it successfully Thanks you guys for your valuable feedback
11-06-2019 03:23 PM
Best to be patient and renew a plan on the next renewal date to avoid issues like this. Click on "Change plan on next bill date" and everything should be fine. I used this method to change my plan and it was flawless. No mishaps. If this doesn't appeal to you, click on ?, bottom right, and follow instructions. A moderator should resolve the issue likely within several hours or a day.
11-06-2019 02:55 PM
Hi @chad2001
I will be happy to help. Before we get started, I will need you to access the link below and use SIMon and create a ticket.
https://www.publicmobile.ca/en/on/get-help
Bogdan_S
11-06-2019 02:52 PM
Refresh the page and try again in a few minutes. Technical issues occur on most websites but correct themselves .If issue persists,contact a moderator by clicking ?, bottom right, and following instructions.
11-06-2019 02:47 PM
I had the same problem, and using a different browser did the trick for me.
11-06-2019 01:55 PM
@Jrt9002 wrote:i did but it cant work for me
Restart your browser and start over with new PM state. Sometime, it got in a state that always produce error. Restart browser will ensure PM will start with a known state.
11-06-2019 01:33 PM
I think there may be something with the website, I have problem even listing the details of my plan
Wait for a bit
Always try incognito mode, preferably chrome.
If it persists, please contact moderators
Cheers
11-06-2019 01:24 PM - edited 11-06-2019 01:28 PM
To submit a ticket to Public Mobile do the following:
11-06-2019 01:23 PM
11-06-2019 01:21 PM
Here is more info.
https://www.publicmobile.ca/en/bc/get-help/articles/change-your-plan
11-06-2019 01:18 PM
can anyone can provide me proper instruction how can i do my change plan
11-06-2019 01:17 PM
Try clearing cache and incognito mode. Or try in an hour
11-06-2019 01:12 PM
when i try to hit button it cant work
11-06-2019 01:10 PM
It is recommeded to change your plan on next renewal so you don't lose any used minutes/texts or data. If you need assistance then submit a ticket by clicking on the question mark on the bottome right.
