Change plan
Sabah2Ahmed
I currently have a 27$ plan with20 GB. I’m trying to change my plan to the $20 plan with 4 GB, but I can’t do it. When I open the subscription page, it only shows three higher-priced plans. I would like to switch to the $2o plan on my next renewal
1 REPLY 1
@Sabah2Ahmed
Unfortunately, you can only switch to plans that are in your account. If it is not listed in your account then you can’t switch to the $20 plan. Try checking next month. PM updates plans you can switch to.
BTW, the current $20 plan only comes with 1gb of data. There might be a $23 plan with 3gb of data in your account.
