02-07-2020 02:40 PM - edited 01-05-2022 09:23 AM
02-07-2020 03:38 PM
02-07-2020 02:55 PM
Forgot about that one @Jb456 . Thanks for the information.
02-07-2020 02:53 PM
@gblackma wrote:@Navneet log in to your self service/my my account and change it there. Lousy advice I misunderstood the question. Do as @dabr says.
Edit Are you talking about your voicemail password or puk code? You can reset your voicemail password from within your account. Puk code. Do as @dabr and @Jb456 says.
@Navneet wrote:How to change my public mobile pin
@gblackma pretty sure he talking about his 4 digit pin for his account. When you sign up and activate you're asked to create a 4 digit security pin.. not what you listed above
02-07-2020 02:53 PM
Only moderator can access subscriber account. We are just PM subscribers like you. PIN# cannot be change using self-serve portal after login.
Create a moderator support ticket for help using the ? button at the right side bottom corner of this page.
1. Tell SIMon that you want to change your PIN#.
2. Ask for "moderator"
3. SIMon will give your 2 choices. Click on the "Account-specific question"
4. Then, click on "No, I want a human"
5. Click "Submit a ticket"
6. Follow instruction to create support ticket.
Good luck.
02-07-2020 02:45 PM
@Navneet wrote:I did but it tells to contact public mobile community
@Navneet If you're having problems with the chatbot send a private message to Moderator_Team here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
02-07-2020 02:44 PM
@Navneet only way to change your account pin is via moderators.
Or private message at link below
02-07-2020 02:43 PM
02-07-2020 02:42 PM
02-07-2020 02:41 PM
You'll need to contact moderators via SIMon here: https://publicmobile.ca.ada.support/chat/
Type in your issue, select contact us/moderators and t submit ticket when these options appear and follow the prompts to finish submission.
02-07-2020 02:41 PM - edited 02-07-2020 02:50 PM
