06-01-2021 11:35 AM - edited 01-06-2022 02:48 AM
06-01-2021 12:08 PM
Thank you!!
06-01-2021 12:07 PM
To update or remove your credit or Visa debit card details, sign in to Self-Serve. Once signed in, click on the ‘Payment’ tab, then scroll to the bottom of the page and select ‘Manage my card’. Here, you will have the option to either select ‘Replace this card’, where you can enter the details for your new card, or ‘Remove this card’. You will need to review and confirm this change to your account and then you’re all set..
06-01-2021 12:02 PM - edited 07-24-2021 09:06 PM
@tetsu8 you can do this with Self-Serve
Payment0> Manage My card (at the bottom on the screenshot)
MangeMyCard
then use the Replace this credit card option
06-01-2021 11:57 AM - edited 06-01-2021 12:08 PM
Update Or Remove Your Payment Card
Once signed in, click on the ‘Payment’ tab, then scroll to the bottom of the page and select ‘Manage my card’. Here, you will have the option to either select ‘Replace this card’, where you can enter the details for your new card, or ‘Remove this card’. You will need to review and confirm this change to your account and then you’re all set..Remember, we accept credit cards (Visa, MasterCard, American Express) and Visa Debit cards that have been issued by Canadian or American financial institutions and are associated with addresses in Canada or the U.S. If you are using a payment card, leave the apartment/suite number in the payment information section blank.
Good Luck
