11-13-2022
09:19 PM
11-13-2022
10:40 PM
computergeek541
11-13-2022 09:23 PM
You can only change the email address on your account with the help from a CS_Agent. You can create a ticket on SIMon Chatbot on the bottom of the page or private message on the envelope icon above.
The hours are 6:00am to 10:00pm EST.
11-13-2022 09:21 PM
You can't do that yourself.
You'll have to have a customer service agent do that for you.
11-13-2022 09:21 PM - edited 11-13-2022 09:22 PM
@Goodlife062404 if you meant the email used in My Account, Only PM Support can help. Open a "forgot password" type ticket with PM support and ask for their help:
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Just in case you are tyring to change email used with your Community, you can change this one yourself here:
https://productioncommunity.publicmobile.ca/t5/user/myprofilepage/tab/personal-profile
