Change email adress
donaldroy
I will be leaving videotron and I need to change my email adress
@donaldroy
If you are porting your old number over from Vidéotron to PM. When you activate your SIM, you can use any email address but if you have an existing account. Contact a CS_Agent to help you change it.
Meow
Only agent can update your email.
To Contact CSA-agent; there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
will13am
@donaldroy , to change the email address associated with your self serve account, please use the chatbot link at the bottom of the web page to initiate a support ticket.
