a month ago
- last edited
a month ago
computergeek541
I chose "Delivery" as the delivery method. But it is delaying.
Would it be possible to change the delivery method to pickup at Telus store?
a month ago
It is probably too late to change., but check with PM
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
