Change Alert Phone Number
Teezem
Where can I change the number used for notifications, text alerts, the number that receives the 75% thresholds and so on. Thanks in advance.
7 REPLIES 7
Teezem
@kav2001c, I actually don't remember, I have a number set as my default but I don't remember setting anything different for texts. Weird.
@Teezem how did you ever get notifications sent to the text number in first place?
will13am
@Teezem, if you managed to have communications text sent to a number different than the one associated with the account, then undo what you did.  Where did you set a text now number?  Anyway, you could discuss this with the moderator team.  They might be able to help.  The moderator team can be reached via private message using this link.  Refer to the following link for information on contacting the moderator team.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
Teezem
It's the number for when you receive texts regarding your usage or yes, 611 messages. I want to change that number once I move to a full plan with phone services. Those messages are currently being sent to a TextNow number.
Payment reminders, notices of limited data remaining, and plan renewal messages are automatically sent to the phone number that is associated with your service.  I do not believe and highly doubt that there is any way to change the phone number that these text messages are sent to.  Is there a reason why you'd want that?  I assume that you handle the payments and such for other family member accounts?
Mana
@Teezem can you please clarify what you are looking for again so that the community member can try helping you out?
thanks
NDesai
@Teezem Not sure what exactly you are asking. Are you referring to text messages from Public Mobile numbers such as 611 that notified you about the payment and renewal? If yes, are you wondering if you can change that?
