04-11-2021 12:57 PM - edited 01-06-2022 01:44 AM
I am considering to buy a Certified Pre-Owned iPhone 8 from public mobile.
On the web site it says :
' They work like new .Tested to ensure 100% functionality, these phones also meet the TELUS standards for physical condition.'
I am wondering if they come with the original battery or replace it with a new one ?
Categories 'Like new' ,'great ' or 'very good' do not give any details about it.
Anybody have an idea ?
Thanks
04-12-2021 02:03 AM
The iPhone 8 was discontinued on April 15, 2020 and Apple will still provide updates for another 5 to 6 years.
With refurbished iphones, the condition refers to the cosmetic looks of the phone. If you put it in a case and install a screen protector, it with hide minor scratches and protect the phone.
I would suggest you look for a refurbished phone with a 1 year warranty encase any problem with the phone arises. The other thing to look at is the battery health, you don't want anything less than 80%...I would ask the seller about that. The good thing is iPhone is more reasonable to have the battery or screen replaced than Samsung phones.
Good luck in your hunt.
04-11-2021 01:13 PM
The battery is likely original. I would expect the add to say reconditioned or similar wording if there was a need to replace parts. iPhone battery replacement can be done for not that much money relative to cost of phone replacement. Personally, I would not be concerned. It would different if it was an android device.
04-11-2021 12:58 PM
@Mamakli wrote:I am considering to buy a Certified Pre-Owned iPhone 8 from public mobile.
Thanks
@Mamakli , i know they come with a SIM card. Not sure about the battery though, good question.
Maybe this is a question for the Moderator_Team to inquire about.
To contact the Public Mobile Moderator_Team, there are two ways to reach them:
1 - Faster Method - Click the bubble comment circle on the bottom right hand side of your screen, or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower Method - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
04-11-2021 12:58 PM
I suspect they do not come with a new battery, unless the phone didn't turn on when tested.
They do come with a 1-year warranty, + a free Public Mobile SIM card to activate.
