Cant get sms texts or calls I have iphone
Codiharmon
I cant contact support and I can't receive sms texts or calls from android users. And when I try and contact support says errors codes. Not sure what to do about this?
8 REPLIES 8
@Codiharmon  Always happy to help ! Even thou you had this little hiccup I think you find it’s worth the hassle for the long term savings PM will bring you 🙂
Codiharmon
Thanks so much for your help!
@Codiharmon  That’s what I thought port hadn’t completed , happy to hear you got it all fixed now and welcome to Public mobile 🙂
Codiharmon
Hen I put in my old sim all my text messages did come through
Codiharmon
I did reply yes for phone transfer. And it worked and I can call other iPhone users but not non iPhone users I will put sim back in and see
@Codiharmon  Did your reply YES to old provider text to confirm the port ? Does old providers sim still work ? . I’ll send you porting team number private message to give status update on the port or re trigger it if needed
Codiharmon
I did just join on Thursday and it was working fine. Now I can't get calls goes right to voicemail. And texts don't go out or receive. Cant even get a code sent to my phone
@Codiharmon  Did you just join  PM did your reboot the phone or did this just start ? Is your account active or on hold ? Can you log in and confirm call *611 to find out .And also here’s a direct link to support
send a  private message   To CS_Agents click
