12-18-2017 07:39 PM - edited 01-04-2022 03:08 PM
Hi,
I changed my phone last week and since then i cant access the internet... Wifi works fine and i do have a data plan and it is paid...
thanks
12-18-2017 08:28 PM
what phone are you using now? is it compatable? have you set up teh apn settings?
this link might help https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-up-Data-APN-on-your-phone/ta-p...
12-18-2017 08:28 PM
Hi @scages!
You will need to enter the APN settings manually for the data to start working.
You can find out the APN settings here: https://apn-canada.gishan.net/
