Cannot send/receive text messages.
anthrskywlkr
Hey Guys!
I activated a $20 text only plan with Public Mobile, on Sept 3rd, my account is active and the phone is working, however I am not able to Send or Receive text messages... I have tried the SIM in another phone, still not working.....
7 REPLIES 7
anthrskywlkr
It has never worked, in any device!
@anthrskywlkr wrote:
I double checked the SMSC and it is set to the correct number, I will have to contact a moderator I guess!
Thank you!
So are you saying it never worked or it was working than stopped?
anthrskywlkr
Thank you!
anthrskywlkr
I am aware that the $20 talk only plan does not include texting...
I built my own plan for texting only, and confirmed all of my plan details before posting to the community..
austinhuang
You might have not properly set up Messaging Center / SMSC on your phone. See here.
If it's not device issue, check your account status or Ask a moderator (Can take up to 48 hrs, 1 message at a time).
If this solves your question, please select my reply as Solution!
@KMG wrote:
Do you mean the $20 talk only? https://www.publicmobile.ca/en/on/plans/20unlimitedtalk
I don't think there's a text only plan.
Texting is not possible with a talk only plan.  You would need to upgrade to the $25 talk/text plan (https://www.publicmobile.ca/en/on/plans/25unlimitedtalk-text).
In the plan builder, you can build a text only plan.  @anthrskywlkr, please login to the self serve portal and confirm the plan features.
KMG
