09-12-2025
01:34 PM
09-12-2025
02:58 PM
computergeek541
I’m using an iPhone and had no problems sending videos before. But today, I cannot send any and I am able to receive videos. I’m also able to send pictures, just not videos. I also tested sending videos to an android phone and it doesn’t work either.
09-12-2025 02:18 PM - edited 09-12-2025 02:18 PM
On Android in order to send MMS, DATA has to be on and to use native SMS/MMS app.
09-12-2025 01:36 PM
Make sure you have Mobile data turned on
and Reset network settings
On Android, you might need to update the APN for MMS to work:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
09-12-2025 01:35 PM
