Cannot receive or send texts
Colb21
I’ve recently switched from a company Rodger’s account to PM they sent me a confirmation that I’m able to switch my number but I did not reply within 90 minutes because I did not know it was needed as the text did not say it was needed.
I can use data, make calls but cannot receive or send text messages I have an iPhone and on messages in settings under iMessage my number just says activation error.
I’ve tried all of the websites tips with shutting down phone removing and putting SIM card back in and nothing is working is there any way to fix this Rodger’s says they have no access to my number now and cannot resend the activation message
is there any way to fix this or will I have to get a new number
it has also been over 43 hrs since I tried to switch
thanks
kingkawhi
im having the same problem with my samsung and wife iphone starting to think switching was a mistake we are currently trying to build a home so not being able to text and sometimes recieve calls is really fraustrating
HALIMACS
Reach out to customer support, @Colb21
Try resetting your network connections first ....
  1. Use the ticketing system for a faster response time. Click here to create a support ticket, then type Customer Support Agent, then Contact Us,  or,
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
Chalupa_Batman
I will send you a phone number to call to get it fixed up. Check the top right corner mail box.
Public Mobile is dealing with issues when it comes to SMS on Android and iMessages and FaceTime and such. There is no ETA of when it will be resolved. Here is their announcement.
We are aware that some of you are currently unable to successfully use iMessage and or FaceTime features,  and we understand how frustrating this can be. Our teams are working diligently to find the cause.
In the meantime, please try troubleshoot steps:
Tap Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings.
We apologize for any inconvenience this may have caused and will continue to keep you updated.
Thank you,
  • Public Mobile Team
Keep an eye on this thread as they SHOULD update it when things are fixed.
https://productioncommunity.publicmobile.ca/t5/Announcements/Open-Issue-Trouble-using-iMessage-amp-F...
To Submit a ticket, please click the following link to access the Public Mobile Chatbot:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type: Customer Service Agent
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
