03-12-2026 11:09 AM
I activated a new SIM yesterday and still unable to receive or make calls or texts. I have tried troubleshooting, toggled airplane on and off, reset network settings and restarted device several times . Pls kindly assist and help.
03-12-2026 11:11 AM
what phone do you have?
can you text and receive text and data work?
since you already tried Reset network settings, you might need PM to reprovision the account.
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
03-12-2026 11:10 AM
@Pedroadekannbi If you need supports help just
