Cannot receive calls
Geethike
Came from rogers network cannot receive calls
Geethike
 It’s working fine now rogers side issue was corrected
@Geethike wrote:
Thank you so much rogers released the number after 4 days
HI @Geethike   All good now?  So, Rogers sent you another text tonight and you replied YES?
or was it a Rogers Home phone ?
Geethike
Hi @Geethike did you reply YES to a text from rogers to approve the porting.
No need to open ticket wirh CS Agent, just call the porting  support group , I think @RossN already sent you the number.   Call and ask them to retrigger the text
Timer
@Geethike
maybe your port not complete, contact to support team by CS_Agent
RossN
@Geethikehi if you ported your number did you leave rogers sim in to receive transfer request? you have 90 minutes to reply yes or your port will get stuck i will send you number for telus porting dept., check your envelope for my message
