06-07-2026 04:47 PM
06-09-2026 04:56 PM
It turned out Bell screwed up, it is now in the process of being transfer. Thanks.
06-07-2026 05:38 PM
Just curious the make and model of your phone?
Your phone must have VoLTE to make and receive calls. Check to see if it is VoLTE compatible by entering the IMEI of your phone.
06-07-2026 04:57 PM
Did you post your phone number into PM?
There is a porting assistance team you can call and ask for update. I can't post the number here, but I will message the number to your community inbox. Please check and call them
But if you cannot reach them or they said they cannot help, you will need to contact PM using this link:
And CS_Agent will reply to your community inbox, check here:
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
06-07-2026 04:50 PM
@b_loyer wrote:
- i am not receiving calls nor SMS. calls go to VM. why?
Are you new to Public Mobile, or have you been with them for a while? If you could share a few more details about what's going on, the community would love to help you track down a fix. In the meantime, if you're already an existing customer, a quick network settings reset or toggling airplane mode on and off usually does the trick for a lot of people here.
06-07-2026 04:50 PM
Check your account if you really have service with PM.
Check your SIM in another phone.
Reboot phone... When did you join PM and did you EVER had service after joining?
