06-11-2020 01:36 PM - edited 01-05-2022 11:39 AM
Hi,
I just transferred my cell from Lucky to Public Mobile.
My "home" phone is using voip over wifi with Fongo Mobile. There is something very strange going on:
- I can call from Public Mobile to Fongo no problem.
- But when I call from Fongo to Public Mobile, my cell phone under Public Mobile never
rings.
- Other numbers can call my Public Mobile no problem.
This is quite a problem because no one at home can call me on my Public Mobile phone.
Any ideas?
Thanks,
Mike
06-12-2020 09:27 AM
Thank you all. Indeed, even though all other numbers could call my PM phone, it took 3 days for Fongo to be able to call PM.
06-11-2020 05:53 PM
Just wait a bit
06-11-2020 04:52 PM
@Mike3003 If you'd like to experiment further send me a private message with your PM #. I'll call you from my fongo #.
06-11-2020 03:59 PM
I did a full reset network settings on my PM phone and still cannot call from Fongo Mobile (app) to PM : (
06-11-2020 03:50 PM
Thanks! It makes sense that it does work. Waiting to see what Fongo will suggest.
06-11-2020 02:56 PM - edited 06-11-2020 03:02 PM
I use Fongo app on my phone.
I use FREE FPL (freephoneline.ca owned by Fongo) VoIP service at home using an ATA box wired direct to my home router using a RJ45 cable.
My PM SIM and my spouse's PM SIM can receive call from Fongo # or from home FPL VoIP call.
I did not change any settings on my Fongo app. All I did was install Fongo app on my Android 9 phone. I have my Fongo app # and my home FPL # at over 5 years.
06-11-2020 02:33 PM
Yes I opened a ticket with Fongo Mobile. Fingers crossed.
Mike
06-11-2020 02:30 PM
@Mike3003 try resetting your network settings
06-11-2020 02:23 PM
+1 on contacting Fongo about this.
See this thread from here on a related issue. Freephoneline and Fongo are from the same company, so try to submit a ticket with Fongo.
06-11-2020 01:57 PM - edited 06-11-2020 02:02 PM
Have you tried bringing this up with fongo? The issue might be on their end
here is a link to their forums http://forum.fongo.com/. I haven’t looked though you may find an answer there.
06-11-2020 01:53 PM
Thanks. I am using and Android and I checked and the option to "Block unknown callers" is not active.
Very strange. I can receive almost any call, but not if the call is coming from Fongo Mobile (app).
Michel
06-11-2020 01:48 PM
Hello,
I understand "It takes about couple hours to a day for Lucky to release your number to PM."
My number has been released to PM and it is working fine. People can call me and it all works.
The problem is my PM phone CANNOT receive calls only when those calls are coming from a voip Fongo Mobile app account.
Thanks,
Michel
06-11-2020 01:47 PM
You said just, do you mean like in the last day?
Make sure your phone is also set to receive calls from unknown callers. My wife's phone wouldn't receive calls from unknown callers so her phone wouldn't ring.
Let us know how you make out and welcome to Public Mobile!
06-11-2020 01:40 PM - edited 06-11-2020 01:43 PM
@Mike3003 wrote:Hi,
rings.
Any ideas?
Thanks,
Mike
For the time being, continue to use your Lucky SIM card until it stops working. That is the indication that Lucky had released your number to PM.
Welcome to PM.
Have a better and better days!
