07-20-2019 03:50 PM - edited 01-05-2022 05:59 AM
Renewed plan, $50 for unlimited talk text and 8.5 GB data. Cannot make/receive phone calls or use data. Can only text locally. Cannot text internationally anymore. Any solutions? Bought SIM card in June and started plan at the same time. First renewal on Jul19 and has not worked since.
07-23-2019 12:19 AM - edited 07-23-2019 12:20 AM
I've merged multiple message posts and threads together into one to help keep things organized. Hopefully, this will help people be able to more easily provide suitable answers and for @garymcg to find them.
07-22-2019 08:25 PM
@garymcg hi what plan are you on did you just renew?
07-22-2019 08:22 PM
@garymcg wrote:I have the same problem. How did you resolve your issues? Public Mobiles failed to get back to me. Thanks Gary
Just FYI, this thread is from nearly a year ago, so you might want to start your own thread so the community can better assist you.
07-22-2019 08:20 PM
@garymcg wrote:Thought someone could help to answer this:
I renewed my plan on Jul 19 $50 for call text and data. I have not been able to make or receive phone calls, unable to use data, and unable to make or receive non-local texts.
Sent three messages to moderator at Public Mobile, but so far have not received any message, and phone remains unusable.
Do you know if there is a phone number to call to get help? Thanks Gary
There is no mobile number to call - PM doesn't offer live support. All you can do is contact the moderator team via the private messages. Though the website states that response times can take up to 48 hours based on the volume of issues they are facing, it seems the wait time may be even longer at the moment, based on some other posts I've been reading in the community forums.
07-22-2019 08:18 PM
07-22-2019 08:16 PM - edited 07-22-2019 08:18 PM
Make a separate thread for your issue, also mods take a day or two to reply, give them time to respond to you, good luck 🙂
07-22-2019 08:15 PM
07-21-2019 01:08 AM
Sent message to moderator yesterday. Nothing works except local texting at the time being.
Hope they can fix this.
07-21-2019 01:01 AM - edited 07-21-2019 01:08 AM
@garymcgYou mentioned your renewal was yesterday.. I assume right now on your overview page everything is dandy?
If your page is fine.. have you tried the Lost Stolen / Found trick?
07-21-2019 12:58 AM
@garymcg wrote:Phone setting same as before.. Location of the phone has not changed either. Not roaming at the present, i.e. I did not travel to another city or province. Weird problem I know
This was a thread about not being able to use services while roaming.
I think I've been seeing your problem a bit in the last day-ish.
You should get in line with the @Moderator_Team < Click this.
07-21-2019 12:56 AM
Never included the +1 in front of the number prior to yesterday and Canada calls worked just fine
07-21-2019 12:54 AM
07-21-2019 12:54 AM
@garymcg wrote:Weird right? Can send receive local text but cannot send/receive international text which is included in the plan.
Are you adding 011 or + in front of the country code etc? For outside of North America.
Your other post: are you including the 1 in front of the number?
07-21-2019 12:53 AM
My active plan includes 8gb. Plan renewed yesterday, and none of that data is accessible yet
07-21-2019 12:52 AM
Same here, all active, plan paid for, but the only thing that works is local texting
07-21-2019 12:51 AM
07-21-2019 12:50 AM
611 works. But cannot make local/Canada calls. Cannot receive calls either.
07-20-2019 10:55 PM
@DMS71 wrote:I added another 250mb and it has not worked at all. Show active and 0 used.
Maybe post a screen snip of your overview page. Blank out personal info of course.
Is your base plan for home active?
07-20-2019 10:17 PM
If you've purchaed the 10 Day US Roaming Add-on within the last 10 days and it's not working. You've tried the cycle phone off/on. Sometimes you have to maually select AT&T or T mobile service.
07-20-2019 10:09 PM
07-20-2019 10:08 PM
Roaming is on
07-20-2019 10:07 PM
Correct. Stopped working. No text,data, talk.
07-20-2019 10:06 PM
Make sure that Roaming is enabled on your phone.
07-20-2019 10:03 PM - edited 07-20-2019 10:04 PM
@DMS71Does the add on appear in your profile? 250Mb (it is not Gig) goes in an instant, could you have had exhausted the data bucket already?
07-20-2019 10:03 PM
@DMS71 wrote:Similar. Added US roaming ul tasks and text, 250 gig of data and only talk works?any ideas why?
Confirmed all active however not working?
So you're currently in US and the 10 Day US Roaming add-on isn't working...correct ?
07-20-2019 10:02 PM
I am out of country and rely on this service plan to work!
07-20-2019 10:00 PM
07-20-2019 04:25 PM
@garymcg wrote:Renewed plan, $50 for unlimited talk text and 8.5 GB data. Cannot make/receive phone calls or use data. Can only text locally. Cannot text internationally anymore. Any solutions? Bought SIM card in June and started plan at the same time. First renewal on Jul19 and has not worked since.
@garymcg What happens when you dial 611 on your phone?
07-20-2019 03:55 PM
@garymcg hi if all you can do is text I would contact a moderator here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
07-20-2019 03:51 PM - edited 07-20-2019 03:59 PM
Log into My Account...is your plan Active or something else ?
If you can text locally...you should be able to text anywhere.
