Cannot make calls or send MMS
TC19
Ported my number over 5 hours ago. Since then I haven’t been able to make calls of send MMS. How can I get this working?
CSA_PM
Customer Support Agent
Thank you for the escalation! The customer is in contact with an agent.
TC19
Thank you, I appreciate the help.
I’m glad you have some knowledge of what’s up because this is all beyond my pay grade.
@TC19 if you cannot make calls this is not a issue with porting, but an issue with the sim card provisioning.
I have escalated your ticket on your behalf.  PM support will reach out to your via Community inbox.  Please monitor here for their reply:
TC19
I replied yes and rebooted phone.
I opened a ticket a couple of hours ago, so far no resolution
@TC19
Did you reply to the text from your previous carrier confirming with YES that you are porting over to PM? There is a 90 minute window for you to reply.
If you did reply, reboot your phone by powering then back on.
If that didn’t work then contact a CS_Agent by submitting a ticket.
