09-21-2025 11:50 AM
I can’t login. I erased my phone and lost eSIM, I only started the account today and didn’t mean to erase the phone. Did it in settings when I was looking at something else. Can’t authenticate using the number because I can’t use the number… now I’ve been charged for a month of use and can’t access it. what do it do?
09-21-2025 12:01 PM
hi @Maple14
try getting the code via email. Click Didn't receive code and select Send email or Send voice message.
if you use send message, you can call back yourself using another phone, click * to retrieve the code
If you cannot get the code that way, ask PM support agent to help
you can submit ticket by direct message:
09-21-2025 11:57 AM
Just download the PM on your new phone then go to Account tab and purchase an eSIM. It should be free if you have an existing account.
You can login to your account on the website and have the 2FA code sent to your email.
09-21-2025 11:52 AM
download the Public Mobile app to your cell...log in to your account...buy another esim (should end up being a free replacement).
