09-22-2024
11:01 AM
09-22-2024
05:14 PM
computergeek541
09-22-2024 11:25 AM
why not try Amazon.ca? it is cheaper too, just $5 vs $10 if you get it in person
09-22-2024 11:20 AM
Hey @Nikki05 around where are you? I've got Sim cards in clare near Yarmouth?
09-22-2024 11:10 AM - edited 09-22-2024 11:11 AM
@Handy1 I get they're in south NS but where? There is a Telus/Koodo store in Yarmouth as well as Bridgewater.
Edit: spelling
09-22-2024 11:08 AM
Hey @Nikki05
If you need a physical SIM, Amazon sells them. Click on AMAZON for the link.
Or locations near you that have a SIM. TELUS STORES
DO NOT buy directly from PM as it can take up to 3-4 weeks to get it in the mail.
09-22-2024 11:08 AM
There in south shore of Nova Scotia , and can’t get physical SIM card there . Might just be Halifax / Dartmouth that had them @Nikki05 have you checked bridgewater Telus/koodo stores otherwise I stick to try Amazon
09-22-2024 11:04 AM
@Nikki05 Is there a question in there? Where are you located?
09-22-2024 11:04 AM
@Nikki05 Order one from Amazon cheaper there too
