Cannot do searches on phone
manofsteel
My account states I have $70 available funds plan says 1gb At 3G speed
I have shut down the iPhone and restarted
APN says sp.mb.com
username and password are blank
Even removed the SIM card and reinstalled
Showing 3 bars
And if what @darlicious  typed above doesn't work, leave those last two lines blank, because it didn't work for me when I used those values for the last two lines.
darlicious
@manofsteel
  Make sure your APN settings are correctly configured for public mobile:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
iPhoneUser
@CannonFodder wrote:
And then there's the semi-obvious solution - make sure data is enabled on the phone....
If that does not work try ......APN isp.mb.com...... add an i
Then reboot phone.
NDesai
@manofsteel Did you verify you have data available to use? Check on the Overview page in your self-serve account. It should be listed in the add-on section. If its not there, then that means you have used up all of 1GB of data.
