Cannot dial 437-972-XXXX number
04-15-2018 04:41 PM - edited 01-04-2022 04:06 PM
Hi,
I've activated service on PM, but I can't seem to dial a Toronto, ON 437-972-XXXX number (calling to a Fido/Rogers Wireless number). The reason for this is probably that the prefix and exchange isn't properly recognized yet because it's a new area code, and the core network believes it to be a long distance call.
Is it possible to pass this information onto Telus' support team?
Phones
04-16-2018 08:47 AM
Good morning @chrstyles,
thank you for getting in touch with us !
If you're experiencing any issues making local phone calls, please send us a private message including your details and we will look into it for you.
Let's keep the conversation going,
Mary
04-15-2018 08:07 PM
@chrstyles happens often with newer exchanges
To test instead of dialing 437-972-XXXX try dialing 437-972-YYYY or 437-972-ZZZZ
If random numbers also do not work then send a private message to Moderator Team
If random numbers do work then there is something wrong with -XXXX specifically
04-15-2018 04:50 PM
@chrstyles wrote:Hi,
Public Mobile's calling plans don't follow traditional local call area rules. In any event, you will need to send a private message to the Public Mobile moderators to get this fixed.
04-15-2018 04:47 PM
@chrstyles, do you have a +1 in front of the number? If not, try adding it. If you already have it, try removing it.
Also, let the moderators know what is going on. They might be able to do something about it from at the network level.
Click here to send the moderator team a private message.
You can find information regarding the moderator team by following this link.
Please let us know what happened. There have been several reports of problems with new area codes (including 437).
