10-30-2017 10:48 AM - edited 01-04-2022 02:50 PM
Have tried numerous times. Can you do that on your backend.
Phone number: 519-***-****
Account: 10000000******
10-31-2017 06:13 AM
10-30-2017 04:15 PM
@rm65453, are you referring to your voicemail pin? If so, you can reset the pin on selfserve by yourself.
10-30-2017 11:44 AM - edited 10-30-2017 12:14 PM
Now the pin is not working for my account. @CS_Agent
10-30-2017 11:07 AM
@rm65453 if you have your credit card on file or available funds, call 611 from your phone and you should be able to add teh minutes from there. PM is currently haveng a bug with their addons in selfserve
10-30-2017 11:03 AM
I am sure one of the Mods can help you from their end with adding the US minutes add-on. I personally, did add the 400 minuts add-on a while back through the selfserve online store without any issues. Your best bet is to send a message to a Mod, and with you ID and situation, and I am sure you will get a remedy asap.
10-30-2017 11:03 AM
Hi @rm65453,
Please refrain from posting your account details on the forums. There is currently a glitch that is not allowing users to add add-ons in the system, which is why you are having problem doing so.
Please send a private message to the Moderators and they will be able to assist you in doing the addition on the backend:
